I cannot figure out this circular chain of reference error
I've attached my simplified example file. If you select the void component and try to cut the infill pieces of the wall, it should give you a circular chain of reference error. Is there a way to avoid this?
I'm using a void component to cut away the brick layer of the existing wall to take it back to the plywood sheathing.
