I cannot delete axis references on curtain walls in REVIT 2021
Hello, I installed the REVIT 2021 and the option to make sloped walls was much simpler, except that when I make a sloped curtain wall and I need to join the panels, I can't eliminate those lines from the axis references that keep appearing. In REVIT 2020, I only moved the cursor with the TAB key and was already able to select the line to delete, however in REVIT 2021 this does not happen, when I approach the cursor even using the TAB key, I cannot select only one line of the axis to be able to delete .
Pin it and uncheck Select Pinned Objects
I don't know how to thank you. Thank you, it worked.
