I can't pan in perspective view
baleti3266
baleti3266
I can't pan, I can't sing, I'm just standing here in orthographic view, because in perspective view panning camera becomes incredible slow. Orbiting and zooming works fine at speeds you would expect.
To be clear it's not about grpahics framerate, but about speed of camera movement (and to be perfectly clear, it doesn't occur in orthographic view).
Is there any way to adjust it?
edwin.prakoso
Does this happen from all perspectives or just a particular one? It's usually because the camera point is too far from the model.
You can try this solution: https://forums.autodesk.com/t5/revit-architecture-forum/revit-2019-is-slow-in-perspective-view-when-...
Cheers,
Edwin Prakoso
blank...
Just confirming the same bug, going back to at least 2021. Sometimes clicking on "home" icon of view cube to reset it helps, other times it doesn't.
I've just given up on perspective view in Revit.
baleti3266
Thanks Edwin, you are right that solution you linked solves my issue as well - adjusting crop view appears to be linked with "speed of panning" somehow
a particular one 😛
