I can't find my wall sweep profile in my project browser under "profiles"
micah
Message 1 of 11
micah
I am not able to locate my wall sweep profile in my project browser. I have looked under "profiles" within "families", but the existing wall sweep profile is not there.  I did a project browser search and no wall sweeps came up. I would like to locate my existing wall sweep profile, so that I can modify it for my current project. Would wall sweep profiles be located under a different family besides profiles? Please see the attached screenshots.
Megan
MSA
Replies (10)
Message 2 of 11
What profile does your wall sweep use? Check the Wall Sweep's Type Properties. The Profile name is shown there.
Message 3 of 11
micah
The default is cornice.
Message 4 of 11
cbcarch
Profiles are in drop down list in Sweep Properties.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 5 of 11
...then that's what you search for: "cornice"; not "wall sweep".   Smiley Wink
Message 6 of 11
Just create a new profile family and load it in your project.
Message 7 of 11
micah
Thank you, but the only profile in my drop down list is default.
Message 8 of 11
micah
Thank you, but I already tried searching "cornice" and no matches were found.
Message 9 of 11
micah
Thank you, I will try this.
Message 10 of 11
I suspect then, that the Profile being used for the existing wall sweep is set to "Default". If you modify that one, I bet your wall sweep with change.
Message 11 of 11
I ****ING LOVE YOU I couldn't find this simple explanation anywhere.
