I Can't delete wall
I Can't delete wall
kittiT5BPP
Message 1 of 8
I Can't delete wall
kittiT5BPP
I Can't delete wall
Replies (7)
Message 2 of 8
RDAOU
@kittiT5BPP
The corrogated sheets are mullions (past of a curtain wall)
  1. If you want to delete them all, to select the Curtain Wall element  >> (make sure it is not pinned) >> delete
  2. If you wish to delete 1 of them or a couple only, you need to tab over the mullion to highlight >> select it >> unpin >> delete
Message 3 of 8
kittiT5BPP
How can I remove this transparent wall?
Message 4 of 8
RDAOU
@kittiT5BPP
See point 1 in previous reply. This is the curtain wall which was hosting the mullions/metal sheets. To select it, you need to change discipline to Architecture.
Otherwise, if a view template is applied and you do not wish to remove, do the following to select the wall, then delete it
  1. Go to the project browser >> Families >> Walls
  2. RIght click the Metalsheetwall >> Select All Instances >> In Entire Project
  3. Hit Delete on the keyboard
Message 5 of 8
handjonathan
Hi @kittiT5BPP
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @RDAOU helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Message 6 of 8
kittiT5BPP
I was able to solve the problem as advised. Thank you very much.
Message 7 of 8
kittiT5BPP
Message 8 of 8
azad.Nanva
Did you mean these panels?
use the Empty System Panel.
