Announcements
I am so confused ? 2024 changed that much or am I doing something wrong ?
talha_ozdemir
talha_ozdemir
Hello I am trying to use the new Revit, but in the beginning there is no option for new architectural project. I also cannot find the elevations tab.
jay_colcombe
Hi, they have changed the Construction Template to Multidiscipline which makes more sense.
You need to Click on Browse and find the Architectural Template to open it (it should open in the default folder and was call Default###).
Then from the Revit "R" Symbol (Top Left) > Options (Bottom) and Add it to your File Locations in Options
There is no Elevation View Folder/Group as there are probably no elevations in the Template you opened.
Jay Colcombe
Autodesk Certified Instructor
talha_ozdemir
Hi thanks a lot.
They have changed the new name to "default" I found it in browse in the default folder.
jay_colcombe
from help.autodesk.com
from revitpure.com
from the RVT 2024 English folder
Jay Colcombe
