HP Omen Laptop
HP Omen Laptop
WFTDesign
Message 1 of 12
HP Omen Laptop
WFTDesign
I have HP Omen 15- AX033DX, Product Number W2N32UA#ABA
Product Description:
  • Windows 10 HomeNVIDIA GeForce GTX 960M 4GB dedicated graphics; Intel Core i7; 15.6" display; 8GB memory; 1TB HDD + 128GB SSD; Bluetooth; backlit keyboard; anti-glare screen; HD Webcam; HDMI output; DVD/CD drive not included
Okay, I bought that laptop last November 2016, at that time I did not know about AutoDesk Subscription. I learned that amazing feature which allowed me to test at least four AutoDesk products, eventually subscribing to AutoDesk Revit LT Suite now. I have 2018 Revit LT and AutoCAD LT! Good start for me!  Sometimes, I can subscribe to AutoCAD Architecture 2018 or Revit 2018, depending on project requirement for my home business.
I am DISAPPOINTED with this HP Omen 15 laptop because it has two hard drives, only tiny 118 GB in Drive C and large 917 GB in Drive D. I am actually running AutoCAD Architecture 2017 trial on Drive D!!! So, I spent too many hours and days moving around files as well as deleting to make room for Drive C due to continuous Windows Updates. I had to contact Microsoft Support to deal with Window Update issues; the major reason was not enough space for Windows Update.
TOO MUCH HEADACHE!!!
Now please tell me what I should look for to buy replacement device? I do hope I will have a good deal in the exchange with Best Buy.
Replies (11)
Message 2 of 12
You need not buy a new laptop.  Just buy a 512GB or 1TB SSD to replace the existing 128GB one.  While you are at it, upgrade to 16GB of RAM as well.
Message 3 of 12
WFTDesign
I agree about upgrading to 16 GB of RAM, but I did stop by at Best Buy and informed me that I couldn't update the RAM.  Geez...
About buying 512GB or 1TB SSD to replace the existing 128GB is acceptable. I will explore that.
Message 4 of 12
I have a hard time believing that your laptop cannot be upgraded to 16GB. Even if it has one slot you can just buy a 16GB stick and replace the old one. I did that to my 6 yo Dell laptop like 3 years ago. You just need to find out the type of RAM so that you can get the compatible one. Go to Crucial's website and run their RAM detection app and it can tell you tge exact model that you need.
Message 5 of 12
WFTDesign
It looks like Best Buy were either telling us the truth or...  Crucial is wrong... take a look at the screenshot
What about 16 GB stick? Plug into a USB slot???
Message 6 of 12
It could be that your laptop slot doesn't accept more than a 8GB module, or it has no slot but onboard RAM, which I find odd since Omen ia supposed to be the gaming laptop. What is the exact model of your laptop?
By the way, no you cannot plug a RAM stick into an USB port. But I am sure you were just being sarcastic.
Message 7 of 12
WFTDesign
Did I say what model was at the beginning?
Yes, it did say Gaming laptop when I shopped, took that one because I have Windows 7 top quality laptop and was replacing the iCore 3 laptop. I must have romped that laptop. LOL.
But if I had known about affordable subscription then I would have been more stricter about buying one.
Message 8 of 12
Maybe both Best Buy and Crucial are wrong.
OMEN 15-AX033DX Maximum RAM?
I would try this one if your CPU is 7th generation i7.
And this one if your CPU is 6th generation i7.
I would buy it from somewhere I could return if it wouldn't work.
Message 9 of 12
Viveka_CD
Hi @WFTDesign
Please see the links below on how to Accelerate Autodesk workflows with HP Z Workstations:
URL HERE
PDF link HERE
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you.
Message 10 of 12
WFTDesign
Thank you for showing me solutions using HP laptops. I will start planning investment into the laptop.
Message 11 of 12
Viveka_CD
Hi @WFTDesign
You are most welcome! Smiley Happy
Please see the system requirements for more information on recommendations for Autodesk products
Use this tool HERE to find recommended system hardware or graphics hardware and drivers.
Message 12 of 12
Team,  I'm also having an issue with my Omen it appears not compatible with CAD software like Revit and another 2D package I'm running.  Menu folders overlap.  I cannot see the line as it is drawn or the dimension.  ( However, it will snap and insert) .
Cannot create an object selection box (i.e. like dimension cannot see the drawn size of the selection box)
Has anyone experienced similar issues as I have changed the diplay settings, turned off the Revit accelerator check box?  However, the latter to date appears to have resolved the crashing of the video card.
