How would you join these walls?
2 REPLIES 2
blank...
219 Views, 2 Replies
blank...
"Wall joins" command doesn't help.
The only idea I have is to abandon trying to join them, lower the "Top extension distance" for the lower wall, and add another type that I would place on top of it to make up for what's missing.
But would still like to learn if there's a proper way to join them.
Thanks in advance!
Thanks in advance!
2 REPLIES 2
in reply to: blank...
Disallow join, stretch the low wall back to meet the corner, and use Join geometry.
blank...
in reply to: ToanDN
blank...
This creates an issue in plan views. Can't be solved even with Linework:
But, once I've done all that, I just allowed join again, and it all cleaned up.
Thanks!
Thanks!
