How would i go about adding a glass plane to this space in the wall or is there a better way
illuscionz
Observer Observer
illuscionz
Observer
Observer
Hey guys very new to revit and mostly using it for archviz renders and how wondering how i'd go about making the space in the wall into glass/window, I've cut out the spaces using the wall opening tool. Or is there a better way to go
about doing this
You could have created the glass as a curtain wall with a basic glass wall as the panel.  Ste the curtain wall to Automatic Embed so it will cut the solid wall to create the opening without having to use the Opening tool.
But since you already have the opening, using basic glass walls and edit their profiles is an easier solution.
