How to visualize the ground patch just till the line window of the section
Message 1 of 9
Hi to everyone I created the ground i just need to visualize the ground patch just more below...till the line window of the section.
How should I do it?
Thank you
Gio.
Replies (8)
Message 2 of 9
Ilic.Andrej
How did you create "the ground"?
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Message 3 of 9
surface topography
Message 4 of 9
Cut the Toposurface in the View.
Message 5 of 9
Message 6 of 9
SteveKStafford
The depth of the cut fill pattern (toposurface) is defined in Site Settings > Elevation of poche base
Steve Stafford
Message 7 of 9
Good reading skills @SteveKStafford.  Better than mine, for sure. I missed the whole "I need to visualize the ground patch just more below" part of the question.
....I blame Evelyn Wood. 😉
Message 8 of 9
syman2000
Go to the Model Site setting and change the poche depth
Message 9 of 9
FacebookGroupMember
The depth of the cut fill pattern (toposurface) is defined in Site Settings Elevation of poche base
Source Message URL: https://forums.autodesk.com/t5/revit-architecture-forum/how-to-visualize-the-ground-patch-just-till-...
