How to Unload CAD file links from Revit model without delete ting it.
archana.sapkal
archana.sapkal
How to unload CAD links from Revit model .
FilteredElementCollector importCollector = new FilteredElementCollector(doc).OfClass(typeof(ImportInstance));
List<ElementId> cadImportIdsToRemove = importCollector.Cast<ImportInstance>().Where(importInstance => importInstance.IsLinked).Select(importInstance => importInstance.Id).ToList();
if (cadImportIdsToRemove.Count > 0)
using (Transaction transCAD = new Transaction(doc, "Delete All CAD Imports"))
FailureHandlingOptions failOptions = transCAD.GetFailureHandlingOptions();
failOptions.SetFailuresPreprocessor(new CustomFailuresPreprocessor());
transCAD.SetFailureHandlingOptions(failOptions);
transCAD.Start();
try
doc.Delete(cadImportIdsToRemove);
catch (Exception ex)
transCAD.RollBack();
return;
transCAD.Commit();
Here I'm deleting links but need to unload links ,How  to possible Unload for CAD files.
azad.Nanva
Why do i need this ?
archana.sapkal
The need to unload CAD file links without deleting them arises when you want to temporarily disable or detach the link for performance or workflow reasons, but still retain the option to reload it later. Deleting the CAD link removes the file permanently from the project, and reloading it would require you to re-import and re-link the file manually.
archana.sapkal
azad.Nanva
so , just unload the link!
archana.sapkal
yes, But for unload their is no any api ,I'm able to unload Revit link using API but unable to unload CAD files link using API
azad.Nanva
https://stackoverflow.com/questions/41915363/how-to-unload-all-links-revit-cad-pointcloud-ifc-from-r...
