Adding UniClass in Family Editor
Mustafa.Salaheldin
Advisor Advisor
Mustafa.Salaheldin
Hello
How can I add the UniClass to the Family in Family Editor.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
azad.Nanva
https://forums.autodesk.com/t5/revit-mep-forum/classifications-uniclass-2015/td-p/10341605
Mustafa.Salaheldin
@azad.Nanva I want to show it in the Family Editor, not in the Project.
¯\_(ツ)_/¯
Mustafa Salaheldin
Mustafa.Salaheldin
In the Family Editor, go to the “Manage” tab, select “Additional Settings”, then “Annotations” and from the submenu select “Keynoting Settings”.
From the dialog browse to the Uniclass text file then press “OK” button.
Now open the Family Parameters
Now assign the proper Uniclass code to each Family Type
The thing is the assignment here is for each Type. I couldn't find a way to assign to the Family level itself.
¯\_(ツ)_/¯
Mustafa Salaheldin
azad.Nanva
this is keynotes !
Mustafa.Salaheldin
This is the closest thing I could find.
We need a proper way to assign different classification codes directly into the family, similar to OmniClass.
I mean to be built in Parameter.
¯\_(ツ)_/¯
Mustafa Salaheldin
The solution here doesn't make any sense.
Isn't this what you are after?
  https://interoperability.autodesk.com/standardizeddatatool.php
