How to turn this into an importable .PAT file?
klintzR76BC
klintzR76BC
Community Visitor
Community Visitor
Hello Everyone,
I work at a firm that is using a pretty complex methodology for fire wall partitions. I understand that .pat files have to be coded to make a custom fill pattern that can be imported into Revit. I was wondering if it was possible to make this hatch in the image below into a custom .pat file? I am not sure how to do this or where to go with it so any help is appreciated. Capture.PNG
You mean you want to use this as a pattern in Revit?  Try using PyRevit.
https://revitpure.com/blog/how-to-quickly-create-a-pattern-in-revit-using-pyrevit
