How to trim the top of stair railing
ip3JJV8
ip3JJV8
Hi, I am currently design a custom railing for a project.  It consists of fence-style panels that are a fixed size.  I have made baluster panel families and baluster post families so everything properly aligns at the desired angle.  The only issue I haven't been able to solve is trimming the top of the top railing.  It currently extends past the top baluster angled post where I want it to end.  I was able to extend the top rail at the bottom of the stairs so it aligns the desired way, I want it to look the same at the top but I can't do it.  Any suggestions?
rxi.gg
can you upload the family to check it?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
ip3JJV8
Here is a project file with all the families needed to make the railing.  It is a bit strange, but the only way I could achieve this condition with these fence panels at the proper angle.
ip3JJV8
Thank you!
