imported libraries from BIMobject
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
bdurao
542 Aufrufe, 6 Antworten
Hi all,
I am using BIMobject.com but no add-in for RVT 2023....
And when I import the furniture families they don't have smooth surfaces and corners (ex: a sofa). Does anyone know why?  Thank you
6 ANTWORTEN 6
Nachricht 2 von 7
rxi.gg
als Antwort auf: bdurao
You must look for other families, even in other formats and not .rfa
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Nachricht 3 von 7
bdurao
als Antwort auf: rxi.gg
Hi Roi, inside bimobject.com? which formats work best in revit in this case? do they include materials/textures as well?
Nachricht 4 von 7
rxi.gg
No, if you want to render it in revit you have to use revit families so you can change materials.
Check other liraries to find families that better match what you are looking for:
https://download.muuto.com/MediaLibrary/Architect-Files-Revit
https://www.revitcity.com/downloads.php
https://www.polantis.com/
https://www.bimstore.co/
https://www.cadblocksfree.com/
https://library.concora.com/
https://www.nationalbimlibrary.com/en/
Nachricht 5 von 7
bdurao
thank you!!
Nachricht 6 von 7
bdurao
So what is the point of bimobject.com if it doesnt work? right?
Nachricht 7 von 7
rxi.gg
bimobject has a huge library, probably other families are better
