how to take skirting material take-off
sonyablade2010
Message 1 of 8
sonyablade2010
Dear All,
I'd like to know how am I supposed to get the skirting material take off, Pls bear in mind that edges common with curtain wall are not supposed to be calculated.
I'll appreciate youtr guidance.
Regards
Replies (7)
Message 2 of 8
L.Maas
To be able to schedule things and excluding others you have to make sure that they can be distinguished. Maybe there is already something that distinguishes the different pieces of skirting. Otherwise you would have to add a parameter, fill it with data, and use that in your schedule to group or filter out the different types of skirting.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 8
RDAOU
@L.Maas I ve scheduled skirting created/modeled from generic model type of family but I find it a pain going room by room adding those components.
I'm just wondering if it is doable for skirtings created by adding a Hosted profile Sweep in the wall type? (Edit Type>Structure Edit>Sweep) I can't seem to find a way to get those sweeps to show up on material takeoff and quantity schedules
Message 4 of 8
sonyablade2010
Thank RDAOU for commenting
That really is very difficult task to complete, room by room, if there is more easier way to do it I really will appreciate it.
Any explanation or workaround for that ?
Message 5 of 8
L.Maas
In general I use the wall sweep tool. Few clicks to place them on the wall, goes around corners, breaks with door and schedules
Louis
Message 6 of 8
RDAOU
I basically do the skirting the same as @L.Maas ... But as I am still on 2014 I just thought/wondering if any new feature has been added which allows quantifing Wall Sweeps embeded in the Wall Type Structure
Adding a screencast just if anyone elese would be interested. Lengthy 10 mins starting falmost from skratch so I'm going to tag it
Skirting, Sweeps, Modify Returns, Skirting Quantities/Schedules
If anyone has a better idea please do share
Message 7 of 8
I applied skirting with wall sweep tool.
Where can I find the skirting quantity?
thank you in advance
Alexia
Message 8 of 8
Create Parts and create Material take off schedule for parts.
