How to sum up the “material: area” and “material volume” for each material?
JamaL9722060
JamaL9722060
I wanted to sum up “material: area” and “material volume” of each material but couldn’t figure out how to accomplish this task
Please, have a look on the attached screenshots
  • The first screenshot shows the entire table
  • The second table show the options that I have chosen to calculate the “material: area” and “material volume” of each material.
Unfortunately, the result doesn’t show the total “material: area” and “material volume” of each material.
Where might be my mistake?
Thank you
Best
Jamal
Jamal Numan
constantin.stroescu
Try this:
  • from Formating > for Material:Area and Material:Volume > check Calculate Totals....
Constantin Stroescu
JamaL9722060
Very much appreciated constantin for the help. This resolves my issue
Best
Jamal
Jamal Numan
Ksenia.Eic
I have the same problem and I checked the "calculate totals" option but it's not appearing in my table. Do i need to turn something on? Also, how do I get it just to list the material once with the total area, rather than listing the area in each wall where it appears?
Edit your schedule:
- Group By: Material
- Uncheck Itemized every Instance.
Ksenia.Eic
Thanks!
