How to stop Align Tools from moving multiple windows in same time
ahmed.xeng
Message 1 of 10
ahmed.xeng
I don't Know why while aligning window in plan view another windows is moving !!
Is there any solution for this issue ?
I am using Revit 2022 and Default Autodesk window family.
Replies (9)
Message 2 of 10
Turn on Constraints and unlock any locked dimensions between windows. Or place dimensions between windows and unlock the padlocks.
Message 3 of 10
ahmed.xeng
There is no Constraints or dimensions at all
Message 4 of 10
No constraints? Have you revealed constraints? The button is at the bottom bar. Or, just select any window and you can see a lock.
Message 5 of 10
ahmed.xeng
Nothing at all
Message 6 of 10
Click this and post a screenshot.
Message 7 of 10
ahmed.xeng
Message 8 of 10
RDAOU
@ahmed.xeng
Try to cut 1 window to clipboard and paste back aligned to same place ... would it still behave that way?
Message 9 of 10
ahmed.xeng
I still have the problem but I found something
Actually the wall it self is moving while aligning and not the window !!
I am not able to select the windows from its edges !! even using TAB key !
Also I tried to adjust window sizes heights and widths and settle levels but nothing changed !
Any help ?
Message 10 of 10
RDAOU
@ahmed.xeng
You are aligning the wall rather than the windows ...
  • Edit the Widow family and set the ref planes (left and right side) properly as reference planes
  • And when you are tabbing through the elements, wait for the bubble tool tip to popup telling you what you have tabbed (it should read the Family name - Reference Plane Name)
Otherwise...attach the family and I will re-edit this post to add you a GIF to watch
