How to state "check if condition is true, true then.., false leave as it is"
Hello again.
Today I am here with a very basic newbie question 🙂
I am trying to write and if formula.
All these parameters are dimensions.
It should be like " Parameter 1 = IF(Parameter 1 > Parameter 2, Parameter 2 - 200, Parameter 1)
And now you saw where the error is, for false condition, I am referring to the parameter itself. What I need to do is just the thing I wrote, but it creates a circular chain of references so revit does not accept it.
What is this very basic thing that I am missing here? Probably I will be ashamed after i realize what was going on 🙂
Thank you in advance.
Btw I am aware that I can make another parameter for checking and it will not give any errors then, the only thing I am curious is is there anything can be done for a statement like " check the condition, if it is not like that, leave my parameter as it is?"
Show us your actual formula.
I attach a screen shot of a basic IF statement:
martijn_pater
It is how @Anonymous says, but I think you need to associate a calculated parameter to the dimension instead of the Parameter 1, as below:
(input) Parameter 1 = x
(input) Parameter 2 = y
(associated to dimension) Parameter 1_calculated = if (Parameter 1 > Parameter 2, Parameter 2 -200, Parameter 1)
Could you elaborate on 'All these parameters are dimensions', what dimensions where? As to provide an answer to the circular chain of references issue.
Thank you for your replies. I figured out as you explained with multiple parameters supporting each other.
