How to show some walls with dashed lines on a plan view?
11 REPLIES 11
Message 1 of 12
8048 Views, 11 Replies
Hello. I have beams  in my model which are modeled as basic walls and represented with dashed lines on plan views.
This means that just a few basic walls are seens with these dashed lines. How do I do this?
11 REPLIES 11
Message 2 of 12
Select the walls, right click snd override elements in view, then change the projection line to dashed.
Message 3 of 12
in reply to: ToanDN
Thanks for the fast reply. What you said makes a lot of sense, however it doesn't seem that it was done that way.
Do you have any other sugestions? (Filters used in this view are not related as well to this).
Message 4 of 12
So they are already dashed and you want to know how they did it? Is the view set to structural discipline and hidden lines set to by discipline?
Message 5 of 12
in reply to: ToanDN
Yes I need to understand how this is done.
The plan view is set to architectural discipline. Another important fact is that these elements will show even if the cut plane in view range is set below them. the family used for beams and walls is the same.
Message 6 of 12
Is there an Underlay assigned to the View?
Message 7 of 12
If you draw a new "beam" wall, does it show as dashed?
Message 8 of 12
Underlay was probably turned on to see the ceiling and the linework tool, <overhead>, was applied to the beams then the underlay was turned off.
Message 9 of 12
I thought of that too. But, if that were the case, then its Properties would not show "Basic Wall". The Properties would show  "Lines".
Message 10 of 12
in reply to: barthbradley
Mine says Basic wall when I turn off the underlay and select the lines as the entire wall is selected.
Message 11 of 12
Ah! Got you! Linework Tool! Yep. I agree with you.  Underlay + Linework tool.
Message 12 of 12
Thank you. I just got confirmation from the creator of that file that was you said is indeed the solution used.
Best regards.
