How to show material Model Patterns in DWG export?
sahin.ikbal
sahin.ikbal
In Revit model I have provided model pattern & drafting pattern as material on walls. When I am exporting the Revit model into .dwg format, those hatch patterns are not appearing. I have also browsed through export section pattern setting but cant seems to make export with pattern or viewing them in autocad.
If anyone knows how is it possible please guide.
ennujozlagam
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Revit-D...
