how to set visibility of lines in skylight familiy
ola6n4qrvdsr
ola6n4qrvdsr
Please refer to the Skylight Family attached
The floor has lower and upper level, the ceiling has upper and lower -- I am trying to get linework , whether model lines or detail/symbolic lines to show on only one of these levels, and not show on any other level, there should be different lines for each level.  This is to enable different graphics for the floor plan below, the floor/roof plan above, and ceiling plan.
Any suggestions please ?
Replies (7)
tiho
You can use the visibility/graphics overrides to turn on and off parts or all of the skylight, and also change the line types. This way, you can apply one view template for plan view, another for RCP, etc.
You can also control appearance from the Visibility/Graphics override by OBJECT Style.
Can you be more specific, with a section showing the levels and floor plan / ceiling plan showing what you need to see differently?
ola6n4qrvdsr
We do use numerous Templates and VG overrides. However, that doesn't work in most projects for this scenario, as these skylights are used on multiple levels of roof -- e.g. roof over ground floor and roof over first floor -- so the ground floor plan will show several skylights above, the upper floor plans will show skylights above as well as skylights below.
ola6n4qrvdsr
Hi Toan
This is roughly the typical graphical arrangement we would like Revit to show on floor/ceiling/roof plans:
We cannot achieve this with view templates as mentioned above, because the skylights are  placed on multiple levels and are visible on multiple levels, per example snapshot below.
As per my original post, I've tried different Visibility Settings and Symbolic as well as Model lines, but with no success.  I thought there might be a simple solution to this, since skylgihts are commonly used this way and the Visibility Settings imply that it was considered, (though all too often perhaps not a functional Revit feature)
curtisridenour
i can get this to work by making the family a generic model. Is that a deal breaker?
i believe it has to do with what categories are cuttable or not. Generic Model families are not cuttable. Even with the nested elements being all Generic Models, if the host family is a window it does not work for me.
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-3253EFCA-F38F-4086-9A4D-C873D8D04867
i separated the object styles into Plan and RCP. You will need to turn off the RCP ones in Plan and vice versa.
ridantuo
Hi.
Is using sloped glazing out of the question?
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-6B7015B8-A758-4768-A384-DDBB95814D2C
You can handle them easier in the templates because they are not windows.
PICNIC: Problem In Chair Not In Computer.
Around 90% of issues can be explained by human error instead of an actual error.
handjonathan
Hi @ola6n4qrvdsr
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @curtisridenour @ridantuo helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Type a product name
