How to set thick section cut
teohjingrou
Message 1 of 19
teohjingrou
This is a section, however the section cut wall didn't appear to be thicker? How can I change it?
Replies (18)
Message 2 of 19
Turn OFF Thin Lines (TL)
Message 3 of 19
lucdoucet_msdl
@teohjingrou
First, try turning off the thin line override:
-luc
Message 4 of 19
teohjingrou
when i turn off thin line, the ground floor plan will become like this? Is there anyway that I only want section cut line to be thick, but floor plan remain thin?
Message 5 of 19
teohjingrou
But my floor plan will become super THICKK also, how do i remain thin line in floor plan but thick line in section?
Message 6 of 19
That's what View Visibility and Graphics Overrides is for.
Message 7 of 19
You need to setup your line weights properly so that they are correct for every view.  Keep in mind Revit prints actual line weights, not thin lines.
Message 8 of 19
teohjingrou
I hv tried to go Manage > Additional settings > Line weight >
but there is no name of the line, all is numbering only
Message 9 of 19
teohjingrou
I have tried to change the visibility graphic, after i apply, it still the same 😞
Message 10 of 19
lucdoucet_msdl
@teohjingrou
From your screen capture, we can see that the Thin Line override is still active which is why all lines are still thin.
Another thing to understand about Revit is that there are several places where objects can be assigned a pen thickness. There is a hierarchy, where you can set the starting object line thickness for all views then you can assign overrides by view using either a family by family override or using filters, and finally you can force an individual object in a view to be overridden for that view only.
This blog post on Revit-Pure is a good starting point: 13 TIPS TO UNDERSTAND LINE WEIGHTS IN REVIT
Hope this helps,
-luc
Message 11 of 19
teohjingrou
May I know what's the name of line for 5) Sectional Perspective, the interior dotted line? I wanted to change it to solid line.
Message 12 of 19
Message 13 of 19
teohjingrou
but where do i change it ya?
Message 14 of 19
Change WHAT?
Message 15 of 19
teohjingrou
How to change the line patterns of perspective line from dash to solid line (as that one you shown is line weight only)
Message 16 of 19
lucdoucet_msdl
Theses lines are not a hidden line type but rather the result of your screen resolution not being high enough to show them as continuous. Zoom into the view and they should appear continuous or print the page to a PDF and zoom check if continuous.
-luc
Message 17 of 19
teohjingrou
This is an exported pdf and I zoom it to the maximum, it appear as dashed line. But when I view the sheets in revit file, it is continuous line haha, so I am quite confused why the pdf outcome will be different
Message 18 of 19
lucdoucet_msdl
@teohjingrou
The broken line appearance may also happen when the wall and roof elements are coincident but not joined. Can you try to attach the wall element to the roof?
-luc
Message 19 of 19
teohjingrou
Yes, they are attached already
