How to set imported image transparent
Message 1 of 10
I  inserted a raster image of  a floor plan as reference, but when I brought it as foreground, it completely  hid the plan I was working on, if I left it as background, the plan I was working on covered the reference image. So how to set the image or the plan I was working on transparent so I could refer the image?  Thanks!
Replies (9)
Message 2 of 10
Turn off the floor that is covering the raster image.
...or use Wireframe
Message 3 of 10
I need the floor and image together, so can't turn off the floor plan.  Do you mean I can set the floor plan as wireframe so I can see through it? How to set it as wireframe? Thanks!
Message 4 of 10
visual style: wireframe is grayed out with floor plan.  I guess it only works with 3D.
My situation is I am trying to work on a floor plan with another floor plan as reference, and the reference is in a format of raster image. I need both of them on.
Message 5 of 10
A Floor Plan can be set to Wireframe. It's probably grayed out because you have a View Template assigned to the view.
Message 6 of 10
I didn't mean turn off the Floor Plan. What I suggested was to turn off your Floor Category in the view.
Message 7 of 10
constantin.stroescu
I use Temporary Hide/Isolate function to hide the floor or/and other entities while working with backgrounds.
You can use also , as Barth suggested here Wireframe visual style...
Constantin Stroescu
Message 8 of 10
constantin.stroescu
you can ,also use a Override by Element > Surface Transparency applied to floor. Take care to rest this option, once your job is ready..
Constantin Stroescu
Message 9 of 10
Corsten.Au
Hi
Create a working view ( duplicate )
import the image ( I prefer to import in CAD, and link CAD in  Revit , so that scale can be managed easily )
and then put every 3d category in transparency to use that image as a backgroun..
transparencytransparency
Corsten
Building Designer
Message 10 of 10
Viveka_CD
Hi @Anonymous
Did the recommendations by the experts help with your issue?
You are welcome to share a screenshot and a file to test further.
