How to set angles below 90° in automatic pipe design?
Good afternoon, I have a problem with the automatic design of the pipe in which it does not allow me to make configurations so that the angles of the fittings to be used are less than 90°, this in order to propose an optimization of the pipe in the design, next I will illustrate the situation that is presenting itself.S1.JPGS2.JPG
jeroen_vanmassenhove
I've had the same question months ago. The suggestion in my question was to use placeholders and edit them.
