How to set a read convention to a Tag text?
Caed9
Message 1 of 21
Caed9
The vertical text reads from bottom to top, but I'm trying to change it to the opposite, read from top to bottom. It only stays like that if there is an angle, or if the element is not in a vertical 90 degree position.
I already tried with the orientation options: Model Horizontal and vertical. and changed the angles but the text fixes itself to read from bottom to top regardless if its rotated as well. Is there a way to change it?
Replies (20)
Message 2 of 21
RobDraw
Drafting standards say your text should be oriented so as to be read from the right side of the paper. Your question should be how to make the lower image tag "readable".
Rob
Message 3 of 21
Thomas.S.Teichmann
@Caed9 There is no way to change that for tags.
@RobDraw Drafting standards? which one? There is a bunch depending on which part of the world you are in.
Aside from that, the lower tag follows the convention: left to right, top to bottom.
Message 4 of 21
RobDraw
@Thomas.S.Teichmann wrote:
@RobDrawDrafting standards? which one?
Why ask me? If you doubt me, Mr. Google has the answers that you seek.
Rob
Message 5 of 21
Thomas.S.Teichmann
@RobDraw
I asked you because you mentioned drafting standards.
For example, I cannot find anything about the text direction for tags/labels in the NCS (which is one standard for the US).
Which drafting standard did you refer to?
Message 6 of 21
RobDraw
There is no particular one. Any beginners drafting class would teach you this.
Rob
Message 7 of 21
Thomas.S.Teichmann
THX.
Pretty long ago that I had a drafting class.
Message 8 of 21
RobDraw
It's good to hear that you actually took one. It also sounds like you need a refresher.
Rob
Message 9 of 21
Thomas.S.Teichmann
Well, after you. 🙂
Message 10 of 21
RobDraw
That doesn't make sense.
Rob
Message 11 of 21
Caed9
nope, could not find anything related to this situation in google, thats why I post the question. Apparently it is not a thing, I'm just trying to recreate some existing structural plans from autocad and the text reads from the left cause I guess it's because that's the front part of the building and it is easier to read from the left as you will start from the front facade (Left side on sheet) reading all the way to the posterior facade (Right side on sheet).  Dimensions are capable of doing so, as they literally have a parameter to change the text to any read convetion(
Right, Left, Up, down, etc.).
I'm not following any reading convention, just trying to recreate those plans as identical as possible, and if revit tags are locked to 90 degree vertical tags to be read from the right side well then I guess there is nothing else to do. Cause I ain't rotating each one to 89 degrees just to get the desired effect.
Note: I made those tags in a hurry in order to post the question that is why they look like that.
Message 12 of 21
I'm not sure what this discussion is about. Are you saying that none of these orientations work for you?
Message 13 of 21
Caed9
Yeah there it works fine cause they are not 90 degree vertical, try changing the read orientation with a 90 degree vertical tag.
Message 14 of 21
You mean like this?
Reverse the Beam Direction.
Message 15 of 21
Caed9
Just like that, All I get is read from the right.
Message 16 of 21
Caed9
How did you do it? I'm tried rotating it many times and it always stays on the rigth
Message 17 of 21
Message 18 of 21
Thomas.S.Teichmann
Nice, not very BIM ...but if Revit isn't willing..
Message 19 of 21
Caed9
Already Changed to model, and it still same on my end
Message 20 of 21
Caed9
I could get it by rotating the tag, before 90 or 180 degrees, like 89.5 or 179.5, getting closer before it rounds.
