How to send Filled Region backward of model elements
AAdawiBIM
Message 1 of 18
AAdawiBIM
Hello all,
I tried to divide my plan (visually) to zones by using Filled Region, but filled region always come to front. I need to send it back of foundations and model elements to be as background. How I can do this.
Knowing that I tried to send it to back, but this didn't work.
Replies (17)
Message 2 of 18
loboarch
There is no way to send detail elements (filled regions) behind model elements. Detail elements are ALWAYS drawn "on top" of model elements in a view. The draw order controls you see are to control the detail elements in relation to each other, NOT in relation to the model elements in the view.
Maybe something you could do with rooms and color fill?
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 3 of 18
You may want to look at using Room or Area color scheme for such task.
Message 4 of 18
Viveka_CD
Hi @AAdawiBIM
  • Try the copy, paste aligned function.
  • Select filled region and then edit so you are in sketch mode.
  • Select the linework and copy to clipboard.Quit sketch
  • Select masking region - sketch the outline for your foundations and model elements
  • Paste aligned current view (to paste the filled region).Finish sketch
  • The filled region will be sitting underneath the masking region to show your model elements in front.filled and masked.JPGPlease mark this response as "Accept as Solution" if it answers your question. Kudos gladly accepted.
Message 5 of 18
@Viveka_CD wrote:
Hi @AAdawiBIM
  • The filled region will be sitting underneath the masking region to show your model elements in front.Please mark this response as "Accept as Solution" if it answers your question. Kudos gladly accepted.
What masking region?  @AAdawiBIM didn't ask anything about a masking region?
Message 6 of 18
Viveka_CD
Hi @ToanDN
The masking sketch alternative is a simple workaround, where we are able to copy the sketch lines between the different element types, because as we know by default a filled region is always going to place itself "in front" of a modeled element.
Message 7 of 18
I don't think that is a good workaround. If pertaining to a drafting approach, he would just have to edit the boundaries of the color filled region to exclude the footing or whatever he needed to show. Why create another layer of drafting items on top of a drafting item?
As I said, there is no need for a workaround if he use color scheme approach.
Message 8 of 18
Viveka_CD
Hi @ToanDN
That is a valid point on using colors schemes.Smiley Happy
More information on color schemes from our knowledge center HERE
Filled regions  allow us to change the color of the pattern and we can choose between an ‘opaque’ and ‘transparent’ filled region within the type properties.However we have encountered a few cases where there have been errors due to a glitch in color schemes and failed color fill calculations and color fills not working on RCP plans.Again these are separate topics, and most functions have a workaround unless reported as a defect/bug. It is beneficial for an user to explore options and our aim is to help others looking out for 'how-to' topics for similar issues, saving time! So here we go:
Applying a Color Scheme
  1. In the Project Browser, right-click the floor plan view or section view to apply a color scheme to, and select Properties.
  2. On the Properties palette, click in the Color Scheme cell.
  3. In the Edit Color Scheme dialog, under Schemes, select a category and color scheme.
  4. For information on creating a new color scheme, see Creating a Color Scheme.
  5. Click OK.
  6. On the Properties palette, for Color Scheme Location, select one of the following values:
    1. Background: Applies the color scheme to the background of the view only. For example, in a floor plan view, it applies the color scheme to the floor only. In a section view, it applies the color scheme to the background walls or surfaces only. The color scheme is not applied to foreground elements in the view.
    2. Click Architecture tabRoom & Area panel drop-down (Color Schemes).
    3. Open a floor plan view or section view that displays a color fill legend. Select the legend, and click Modify | Color Fill Legends tabScheme panel (Edit Scheme).
    4. Click Architecture tabRoom & Area panel drop-down (Color Schemes).
    5. Open a floor plan view or section view that displays a color fill legend. Select the legend, and click Modify | Color Fill Legends tabScheme panel (Edit Scheme).
    6. Foreground: Applies the color scheme to all model elements in the view.
Opening the Edit Color Scheme Dialog
When working with color schemes, you use the Edit Color Scheme dialog to perform many tasks. Use any of the following methods to access this dialog.
  • Click Architecture tabRoom & Area panel drop-down (Color Schemes).
  • Open a floor plan view or section view that displays a color fill legend. Select the legend, and click Modify | Color Fill Legends tabScheme panel (Edit Scheme).
  • For a floor plan view or section view, access view properties. On the Properties palette, click in the cell for the Color Scheme parameter.
Related topics
Message 9 of 18
Try this:
In property, tick off the box for masking(Last option in Graphics), then adjust the object order.
Message 10 of 18
MichaelWarwick7522
Since detail items always sit in front of model elements, either use a fill that is set to transparent so the model elements will show through, or use a colour fill scheme, or use model elements. You can use existing floors with view overrides for example.
Message 11 of 18
I thought this was true then this happened. A filled region cannot show up in front of a glazed curtain wall. I was going to use it to show a patterned of glass. I can figure out a work-around, but it kind of surprising to see rule like this upset.
Message 12 of 18
loboarch
There must be something else going on. I had no problem placing a filled region in front of a curtain wall element. No way to send it behind it.
Jeff Hanson
Revit Help |
Message 13 of 18
This is the answer.
Thank you,
Message 14 of 18
The other solution would be to edit the boundary line of your filled region, create the cut from where the element needs to be out and seen like as shown below. Because even if you override the transpancy its still unclear so i cut the portion where the filled region covered the element I want to show on top.
Message 15 of 18
layla.k.ryan
Community Visitor
Community Visitor
I am not sure if this was already said but I was looking for a similar solution for my plans. I used the area colour legend but some 2B are duplicated that I need grey and others are original that I need white. My solution was to use a field region that is not masking to cover the grey for the 2B I wanted white.
Message 16 of 18
kayla.snow2
Community Visitor
Community Visitor
Best answer!
Message 17 of 18
nicholas.tsagkosTNEJX
I have a similar issue, the filled region someone created is hiding the foundation.
I don't want to use transparency as this will also change the colour shown elsewhere.
Message 18 of 18
aflferraz
Am I missing something? The filled region (red square) appears over the floor but I can't sent it over the beam (beam top elevation is above the floor).
The only way I manage to bring forward the FR is if that I level the beam with the floor, but this is not a solution.
The "bring front/back/forward" doesn't work at all.
