how to see a special parameter on a schedule
TomasoCardia
TomasoCardia
How can I vizualize this parameter on a Schedule?
(I have made the parater with this tutorial: http://therevitcomplex.blogspot.com/2013/06/report-length-of-any-curve-including.html)
Thank you all!
Sahay_R
Have you created the Shared Parameter per the tutorial? Have you added it to your Project and associated it to Walls?
You will need to add the shared parameter that you have created to your Schedule fields. That will create the field reporting the length of curved walls. Good luck!
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
TomasoCardia
Hi, thank you for your answer.
It is not a wall, it is a mullion
Sahay_R
Aaahh. I stand corrected.
 Associate the Shared Parameter with Curtain Wall Mullions then.
All else remains the same. You may need to create a Multi Category schedule for this.
Rina Sahay
@TomasoCardia
You need to add the same shared parameter to your project and assign it to the Generic Model category (assuming you created the adaptive family in this category).
