How to schedule a Revit model not made by your standards?
semi
semi
Hi all,
I'm currently making a schedule list of a revit model for cost etc
The problem is the model was not designed by myself and is entirely different.
There are no keynotes, no assembly codes used, so I cant link them to my normal way of scheduling and exporting to Excel based on a database made by keynotes.
How would you guys handle this? Could you show me a workflow? Because adding keynotes to every geoemtry and family in this revit model would take a lot of time and clients dont want to pay for this.
HVAC-Novice
I think you have to explain more what your normal workflow is. You use keynotes and then somehow export them to Excel and perform cost calculations in Excel?
I assume you have a template and that is what you mean by "your standards". You basically have to re-create in that  project whatever makes your template perform as you wanted.
Revit Version: R2026.3
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
semi
see below
semi
Exactly,
I link my cost schedule to a Word-Excel file via Keynotes:
For example "steel beams" have keynote 27.11
This translates into my template txt file:
Which then schedules in Revit as:
And exported with a dynamo script to txt
And finally exported in Excel for the calculations:
So without this workflow I can't do anything with any form of Revit model without integration of my own template.
