How to scale the size to fit in the sheet.
Wilson00000
Wilson00000
I would like to put the elevation in to A3 sheet, but there are some problem.
1. When i chose view scale 1:500, it is too small for A3. But when i chose view scale to 1:200, it is too large to fit in A3.
2. When i chose 1:500, the level mark was too large
Corsten.Au
Hi
1. In Revit, for any views, the default scales are 1:100, 1:200, 1:500 and so on, and if those scales
are not fitting then you can use "CUSTOM "scale and use 1:150, 1:250 for that matter any scale.
2. The View port tag, levels etc, they are constant size on print scale, no matter whats the VIEW SCALE.
3. You can always custom / create new / edit existing "Level Head" Search for the Level head used for the
Levels, find it in Family, and change the text size and level head size as per your requirement..
Example of Level head triangle.
Corsten
Building Designer
@Wilson00000: Sounds like the Goldilocks Paradigm: 1/200 is too small, and 1/500 is to large.  How about a view scale in the middle?   1/300 or 1/400?
