How to rotate dividing points of a circle in revit
kadiravanarjun
Message 1 of 12
kadiravanarjun
Hello everyone!
I divided a circle in generic adaptive family but i want to rotate or shift all the points to certain degree as shown in the bellow image
Replies (11)
Message 2 of 12
Have you tried rotating the circle?
Message 3 of 12
kadiravanarjun
i tried but its not shifting the points
Message 4 of 12
MostafaElashmawy
First of all, switch the show node numbers, then calculate the arch length between the first and last point.
then use the Beginning Indent and End Indent to place the first and last point correctly noting that they measure in an opposite direction.
Check below photo for reference.
Mostafa Elashmawy
Message 5 of 12
constantin.stroescu
another method could be by using Dynamo:
Constantin Stroescu
Message 6 of 12
Or simply draw 2 semi-circles instead of one circle.  When you rotate them, the points will follow.
Annotation 2020-01-03 113141.jpgAnnotation 2020-01-03 113158.jpgAnnotation 2020-01-03 113230.jpg
Message 7 of 12
kadiravanarjun
thank you very much for replying and it works, but how did you measure the arc distance between those tow points? I tried arc length dimension tool but not able to measure the arch distance between the points
Message 8 of 12
MostafaElashmawy
Select the arch length dimension tool then hover over the point then click "tab" to swip between the available selections, once the point is highlighted. Left click the mouse.
Do the same for next point.
"Tab" switch between selection options, tab tab tab till the required point is highlighted then select it.
Mostafa Elashmawy
Message 9 of 12
kadiravanarjun
I am using Revit 2020 and I am not able to highlight the point with arch length dimension tool in hand despite pressing the tab key multiple times
Message 10 of 12
MostafaElashmawy
I think that you are not putting the mouse above a point.
this tool can't measure except from a point or a line.
to understand me, in your previous example it can measure only between the 8 points dividing the path.
Mostafa Elashmawy
Message 11 of 12
MostafaElashmawy
Ah sorry I think I forget to tell you that you should select the circle first.
1- select the tool
2- select the circle
3- select first point (even if it shows as not selected)
4- select the second point.
5- place the dimension.
Mostafa Elashmawy
Message 12 of 12
kadiravanarjun
Thank you soo much, I managed to get the arch length
