How to rotate an entire project?
Jonq12345
Message 1 of 21
Jonq12345
Hi all,
I need to rotate my entire building of 90 degrees without change the value of the angle of the project true north. Is there a way to do that?
Replies (20)
Message 21 of 21
Snider.Eric
instructions below stated:
"A proper workflow is NOT touching your Project North, your True North, your Project Base Point, your Survey Point; link the Site model in your file (center to center or origin or origin, doesn't matter), move and rotate it to align with your building, then acquire coordinates.  That will take care of everything you are trying to do manually."
This is 100% correct. No loss of annotation, sheet setup, view setup, etc. Disregards ALL other instruction on this solutions page.
