Script error - unable to launch Revit 2020 installer
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
GlynnisVP
5275 Aufrufe, 9 Antworten
I have updated my Autodesk Licensing per the hotfix and have access to Revit 2020 through subscription. Presumably it has completed its downloading activity because it shows a Launch button. When I pick the Launch button I get a scripting error.
I did a clean uninstall of the beta via the Uninstall tool and also did a reboot - 2x for good measure. I have also logged out and back into my subscription. I am using Windows 10.
What's next?
Glynnis Patterson
www.ideatesoftware.com
9 ANTWORTEN 9
Nachricht 2 von 10
Viveka_CD
als Antwort auf: GlynnisVP
@GlynnisVP
Are you still able to launch Revit after you continue running the scripts?
Nachricht 3 von 10
Viveka_CD
@GlynnisVP
Can you close open browsers, if any and clear your temp folder, and let me know if this helps?
Nachricht 4 von 10
GlynnisVP
als Antwort auf: Viveka_CD
Hello Viveka,
I've tried selecting both the Yes and No options on the scripting error, but both result in the same, which is that it's all frozen and I need to use the Task Manager to shut it down. I just restarted for a third time and now I got to a new stage, but it's erroring with a message that says: "The License Manager is not functioning or is improperly installed. Revit will shut down now." I tried a fourth time and then got it.
Thanks for your replies. I am now up and running.
Glynnis
Nachricht 5 von 10
Viveka_CD
@GlynnisVP
Thanks for your response. Glad you got this resolved.Smiley (fröhlich)
This error occurs on the system that has a third party program is preventing the start screen from launching  ( a system that has LogMeIn installed) , please see article: Error: "The License manager is not functioning or is improperly installed" on systems with LogMeIn i...
(*let me know if you have log me in installed)
Also see: Error: "The License manager is not functioning or is improperly installed" displays when launching A...
Since the above articles are AutoCAD, I will create one for Revit and share the Public URL here.
Nachricht 6 von 10
I have the same problem. I do not have log me in and have emptied my temp file. I uninstalled and re-installed Revit and have the same exact error message.
Nachricht 7 von 10
Viveka_CD
als Antwort auf: Anonymous
Hi @Anonymous
Can you take a look at the solution in this blog and let me know if this helps?
Nachricht 8 von 10
ZinMinPaing.183
This script error solve is not effect on my computer .
I do this way is not Ok for me.
So  Can I know another way of script error
Nachricht 9 von 10
IT WONT HELP...IS THERE ANOTHER WAY OR MORE SIMPLIFIED APPROACH IN THIS PROBLEM? THANKS AND REGARDS.
Nachricht 10 von 10
katie.muttonAM2KR
I am also receiving this problem.  I applied for a teacher plan, and received a confirmation email.  But still getting the same scripting problem. I had to download 2019 as 2021 didnt even want to open or start
