How to Represent Column Below?
I just find it necessary to represent the columns below any active view for my structural plans as I am working with a multi level building that has reducing column sizes as the floors goes up. For the floors above ground floor, I have my slab, walls, beams and columns visible and just for extra reference I want to include the column below the level to be represented maybe in thick broken lines or in a different section fill pattern. in the picture below, the one with the solid fill is a planted column or can also be a continuous column while the one with a diagonal pattern a column that terminates to the floor level. I hope you can answer my question. Thank you in advance!!
