How to rename existing Global Parameter input?
ctough
Message 1 of 21
ctough
Is there anyway to rename an already inputted Global Parameter?
Replies (20)
Message 2 of 21
What Version of Revit is that?
Message 3 of 21
ctough
2023 - Full version
Message 4 of 21
It looks like you have a Project Parameter (not Global Parameter) named "Category" and you want to rename it.   If so, edit the Project Parameter.
Message 5 of 21
ctough
Oh, I see. Sorry, a Project Parameter then.
That's right, I created the 'Category' but I want to rename/delete the name of the categories. As you can see from my screenshot, it says 'Option 1' - that's what I want to rename/delete. Do you know how I can go about it?
Message 6 of 21
Create a schedule > go to Sorting / Grouping tab > sort by Category, untick Itemize every instance box > then change Option 1 value in cell.
Message 7 of 21
Sounds like you want to rename the actual Options.  That's done by editing and renaming the Design Option.
Message 8 of 21
ctough
I've updated my Options already to include 'A' and 'B' now, see below:
Now I want to be able to delete/rename the below highlighted list to reflect my new Options:
I can add the newly titled options by simply typing in the field - 'Option 1 - A' etc... but I can't find a way to access the list and edit it.
Message 9 of 21
Do what @ToanDN suggested.  Edit list through a Schedule.
Message 10 of 21
  1. Design Option Sets  and Design Options have nothing to do with values of the Category project parameter.
  2. The list you see in Category automatically shows any value being used.  To edit a value, you need to select every element with that value and change it.  It is easier to do it via a schedule with sorting/grouping as I described earlier.
Message 11 of 21
Out of curiosity, what is the purpose of including this Project Parameter in View Properties?
Message 12 of 21
ctough
Great! Thank you! I've managed to access the list as per your instructions. I can see how to delete each cell but not edit?? No biggie though.
Message 13 of 21
ctough
So I can group the views, like this:
Message 14 of 21
@ctough wrote:
Great! Thank you! I've managed to access the list as per your instructions. I can see how to delete each cell but not edit, no biggie though.
No do not delete any row, if that is what you mean.  Because that would delete actual views in the model.
You can click in a cell and edit the text.  If you cannot do that, it usually some views have a template assigned to them.  In such case, you would need to edit the view template.
Message 15 of 21
That's exactly what I figured.
Sweet Browser Organization.
Message 16 of 21
ctough
I see.
I can't edit the cell in the schedule. I do use View Templates but can't figure out how to edit the Category Title, eg. 'Option 1' into 'Option 1 - A'.
I also tried to delete a cell with all of it's views but it didn't delete the title from the Category list.
Thanks for your patience.
Message 17 of 21
ctough
Thanks!
I wish my firm appreciated it (cue tiny violin).
Message 18 of 21
Just highlight all the views in the browser with Option 1 and change to Option 1A.
Message 19 of 21
ctough
Sure, that changes the title of them all but I'm left with the old 'Option 1' now, that's what I want to delete:
Message 20 of 21
ctough
Sorry.... I hadn't selected all view, I missed one, this method works!
