Filled Region not visible on Architecture Discipline
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
SdinizF
639 Aufrufe, 10 Antworten
I created a new family as Electrical Fixtures that contains a fixture and 2D drawings with a filled region.
When I set the discipline to Architecture, Coordination or Structural, the filled region only shows its borderlines, the fill becomes void.
It works with Mechanical, plumbing and electrical disciplines.
Can someone help me? I want to create an Electrical Fixture (with the Electrical Connector) with only 2D drawings.
The problem of using it with Electrical Discipline is that all non-electrical becomes "halftone" and I can't control it.
The result I want to achieve:
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: SdinizF
Post the family here.
Nachricht 3 von 11
SdinizF
als Antwort auf: barthbradley
Here is the file. Thank you!
Nachricht 4 von 11
I can't replicate what you are describing. The only issue I see, is that the Fill isn't constrained properly.
Nachricht 5 von 11
Post the Project File (RVT).
Nachricht 6 von 11
SdinizF
I created a new empty RVT file and had the same result as you, so, I searched in my file and the problem seems to be on visual style. It is working fine on "wireframe" but not in all others. I can't find what setting is causing this.
Sending a copy of the project attached. Look at the floor plan.
Nachricht 7 von 11
SdinizF
File
Nachricht 8 von 11
You devices are at 0 so that the filled region is covered by the floor plate.  Set the devices above 0 elevation or hide the floor.
Nachricht 9 von 11
The fixture is buried in the floor. Raise it up.
Nachricht 10 von 11
Sh*t! That was waste of my time. :zwinkerndes_Gesicht:
Nachricht 11 von 11
SdinizF
als Antwort auf: ToanDN
Thank you for all help!
I created a masking region and now is fine.
