How to remove join lines in planviews?
Caed9
Caed9
Hi Revit community, I've posted several times concerning this issue, but it keeps causing problems on the views.
Please check the video I uploaded, I'm having issues with joining walls and columns
I'm currently working in two disciplines, on the architecture plan, I just want the columns to join without any join lines. I just want the walls clean, I do not need the flushed columns to show up.
However, I want the columns to show up in the construction plan, in order to dimension the structure.
I set both columns and walls to coarse in visibility graphics, but it does not seem to help.
I already applied the same material to all walls and columns. But some columns keep showing up with all the contour lines. Is there a way to fix it? Or do you recommend me to just handle two different Revit files and link them? I am really tired of joining and switching join order, it works in some elements but not on all, I can't get the desired visibility display on both plans. I tried linework and set them to invisible but I get a wall with irregular lineweight.
Every time I try to fix them my elevations are showing the join lines once Again.
I appreciate your help and treasure your feedback!
RobDraw
Wouldn't it be prudent to continue with one of your other threads? That would prevent any duplication of possible solutions and save time for the people trying to help.
Rob
Caed9
Yeah, I kind of fixed it as the issue was in 3d views and elevations on my other post, now I am having issues with plan views,. but thanks for the feedback. I'll just check my old post maybe someone replies.
Thanks @RobDraw
