I'm using Revit LT 2020.1.1 and when I duplicate a floor plan then switch the discipline to "Electrical", the interior walls disappear. When I switch the view style to wireframe, I can see them. But on hidden line view style, they are not shown. It appears that they are masked by the main floor concrete slab which is set at the first floor line. My view range is set with a 4'-0" cut plan.
Gelöst! Gehe zur Lösung
Gelöst von otr.drafting.design. Gehe zur Lösung
So I fixed my own problem but thought I'd share the solution in case anyone should run into the same issue.
If your "Underlay Orientation" is set to "look up" then a floor will mask the walls. It makes sense now but I had only used the underlay feature for checking for interferences.
