How to refresh a schedule in revit?
Message 1 of 10
How do I refresh/ reload a schedule in Revit?
Replies (9)
Message 2 of 10
Ilic.Andrej
How do you refresh yourself? Smiley Very Happy
What do you mean reload/refresh? What is going on? Is there something wrong?
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Message 3 of 10
Corsten.Au
Select the shedule
move/ nudge it ( on sheet )
that should refresh it.. no kidding..
Corsten
Building Designer
Message 4 of 10
unbelievable.....
Message 5 of 10
XXalessio.amodioXX
Revit is a BIM Tool so the schedules "Refresh" automatically. Basic
Message 6 of 10
brunno.b-VEC
Some parameters do not refresh automatically 🙄, it happened to me in an Assembly column. To make the column refresh I pressed the Hide/Unhide button for the column that needed to update.
Message 7 of 10
Corsten.Au
Seems the newer version of Revit specially 2021 gives all these issues.
Corsten
Building Designer
Message 8 of 10
HVAC-Novice
i didn't notice (nor pay attention) to tha tin 2021. But in older versions i had noticed that a schedule on its won woudl update immediately, but a schedule on a sheet would not. It will updated whne you re-open the sheet, though.
If that still is a bug, I guess just look on the actual schedule.  Befor eyou actually print a plan set, you sure have closed sheets and re-opened, so they will  be updated.
Revit Version: R2026.4.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Message 9 of 10
mdelavar
It seems not reasonable, but saving the file 'somehow' refreshes the schedules (for those parameters which do not get refreshed automatically!) I see this in Revit 2021
Message 10 of 10
jokaumo
Wow can't believe it, but this works.  Revit needs to fix that.  Rediculous.
