How to realign UV grid when using "Divide Surface" or curtain wall systems
Raylionn
Raylionn
My problem is shown in the attached screenshot. Whenever I use Divide Surface or create a curtain wall system, the U and V grid is aligned to the top edge. I have tried to google for everything I could think of and tried everything I could in Revit, but there seems to be no way to realign this. I know that I can rotate the U and V orientation, but I want it to be perfectly aligned with the ground. I'm new to Revit so sorry if this is actually super easy, but please, if anyone knows how to do this, I would be most grateful for your help.
constantin.stroescu
In Edit Mode of Mass:
  • use Align Tool
  • select , first the horizontal Face and then the Grid line
  • the same with the vertical Grid
Constantin Stroescu
Raylionn
Thank you so much, I had a feeling it was actually very easy. As I said I'm still new to Revit and getting used to what works with what. Have a great day.
akiHKNEH
I've been trying to figure this out!!
Thank you so much!
Andy6640
Yes, but if you stretch an edge, the alignment does not update, even if locked. At least not in my environment.
