How to prevent textures from scaling?
Message 1 of 10
I'm trying to make a floor finishing concept with Revit. I have various textures (usually in size of 300x300 px) for different types of floors. The problem is that when I zoom out to see the whole floor, the textures are not very visible - only the overall color of the floor is visible - one can not tell what is the floor really made of.
I tried to solve it by making the texture files very big, but it does not solve the probllem for all of the cases.
Replies (9)
Message 2 of 10
artejon
You can use a drafting pattern to indicate different materials under type properties of a floor, choose the one that is appropriate to the scale of your views.
It will also be scaled while zooming however it will keep it's size in relation to a view scale when it changes. Drafitng pattern may be a better solution over image files that can slow down your computer.
Revit add-ins: CAD Purger (delete UNUSED and selected line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager at Revit Apps Store
Message 3 of 10
Thanks for replying. I tried to follow your solution. Went to floor type properties, but there are only drafting patterns for coarse scale adn there is no way to attatch a texture to it.
Message 4 of 10
artejon
You have to assign a drafting pattern as a surface pattern to a material used as a finish under Structure>Edit in type properties of a floor.
Message 5 of 10
I might be missing something here, but it still only allows me eihter to use one of the hatch patterns that are already there or import one.1.png
Message 6 of 10
artejon
Choose any existing drafting pattern.
Message 7 of 10
Thank you very much for the feedback but I still think that I am missing something. I have chosen some surface pattern, then tried to align the texture which did not work (when I clicked on the arrows nothing happened). I applied the changes bu there was no change on my project view. I though that it is maybe because of the Detail Level but everything stayed the same when I changed it.
Message 8 of 10
artejon
Have you switched to realistic to see a texture in a view?
Texture is repositioned with arrows in a view even if you can not see changes in a material editor which happens if your surface pattern is a drafting pattern.
Message 9 of 10
Yes, I am in realistiv view. I am still not sure though if I am following your thoughts properly. Would you like maybe to make a screencast showing what you have in mind? I would really apprieciate that.
Message 10 of 10
artejon
Could you tell which element is causing you a problem:
- fill pattern
- texture ?
It would help to know what you are actualy trying to achive right now after applying a drafting pattern to a floor.
