I am creating a Sweep with a simple rectangular profile in Generic Model Adaptive Family.
Reason: The sweep is having curvature both in Plan layout and Longitudinal Section. Like a Rail Road.
What I did:
1. I used Generic Model Adaptive.rft template to create a blank family file
2. Added Reference Points
3. Set an elevation (Z Value) for them
4. Created a 3D Spline by selecting those Reference Points
5. Selected the line and In Instance Properties, clicked on the Check Box, Is Reference? => Yes
6. Select the beginning of the Reference line
7. Set the work plane perpendicular to the Reference line,
8. Created that Simple Cross Sectional Profile of a rectangle
9. Ctrl Selected the Rectangle and the Reference Line
10. Created Form.
Now the problem is, the profile is not upright vertical and in many locations, it is tilted.
Pic 0: In Wire Frame Mode, The Reference Points, 3D Spline Created out of it (Green Line; Turns green when Checking Is Reference? = Yes) & Created Sweep.
Pic 1: Cross section of the Sweep Form is tilted
Pic 2: The Plan view of the Sweep has 4 projection lines since the object is tilted about the Reference Line / Axis of Sweep.
Now which setting should I change to make it upright and vertical?
Thanks in advance.
Since it is more like a track...it is hard to keep the profile straight cut vertical (plumb).
Several comments on your method
On your issue with the straight plumb profile...
For the profile..
OR ... you can make 4 perfectly leveled / parallel spline tracks host on each a point and set the NCP of all 4 to sync their movement then connect those (pair-wise) with a ref line then sweep those ref line
If the above makes sense to you mark the solution...I will prepare a screencast if I find some time after finishing screencast for the other post from JasonLlindner
Here is one screencast on how to do it...there are several other ways too; but all circle around the same principle (profile should be hosted on a properly guided track (ie: always horizontal/vertical)
I used
a better method which I thought of after doing this, might be using a parametrized divided path with repeaters
Kindly mark solution if you find it helpful and to help others as well
Hey RDAOU
Sorry for the intrusion but Does this apply also to pattern based families? Or is does that have some other method? I've been having similar issues with that maybe you can help. Or better post it as new question?
ps: for whatever it's worth; I think you're the boss of adaptive components on this forum! You seem to be the only one to answer such questions! Even those posted by people who never or rarely mark awesome replies as solutions! Pity and shame
🙂 thanks I'm flattered lol ... Won't be around for long though
to your question; best if you submit it as a new post. They are somewhat similar topics but not exactly similar. Best would also be if you provide a rvt file or images of what you are working with, screenshot is ok too. unsubscribing to this post.
PS: people are free not to accept solution (that would be only to help others find reply to a similar case) besides it comes usually out of one's courtesy 🙂
I can't...apparently it showed contents from the workstation's desktop when I did it and which someone seems to have noticed it...I wasn't aware I needed prior consent before publishing that (at least not something that insignificant!
So here is a simpler one from my home PC! (I didn’t use a profile...I think you should be fairly ok with modeling one and nesting it in)
You just need to host the profile to an "always vertical" or "always horizintal" element
