How to place beams on columns with corbels?
blank...
Advisor Advisor
blank...
How do you place beams to go all the way to the column when columns have corbels?
Out of the box Revit families, "Concrete - Rectangular Beam" and "Precast Column - Rectangular - Single Layer Corbels".
It goes up to the corbels but I can't get it to go up to the column it self.
I thought I'll just manually "stretch" it, but cutback property is also missing for the beams.
Disallow join the beam and grip stretch it manually.
alan.johnson7YLND
I would try loading in a precast beam, that will give you the end shape handles.
blank...
There I go, overcomplicating again. Thanks!
