how to opt to include or exclude a nested family while volume data changed accordingli
heichan88
heichan88
I have a host family that include 4 nested families A at 4 location, where optional to exist or not exist (eg 3 exist 1 not),  and the volume should change accordling (eg only 3 is counted and deducted by 1), some like a door with or without 1 or 2 hinge or 1 or 3 handle
I had tried visibility but volume not affected.  And adding a cut void parameter (cut to no-exist or not cut to exist) seens works -- but
is there any more direct parametric way to control the exist or non-exist of a nested family while volume can calculated accordingly?
Accepted solutions (3)
RDAOU
@heichan88
If you are using generic models category, the volume would
  • either need to be a calculated value
  • or extracted using dynamo and set to a parameter in the family.
  • or create a Take-off schedule and use the field Material: Volume.
heichan88
Hello Mr RDAOU,
and can the schedule can filter to include or exlude that opted nested family? ( by whcih parameter eg visibility or cut void or by label?)
RDAOU
@heichan88 wrote:
Hello Toan,
@heichan88
Toan? 😆 who is Toan?
If the Y/N visibility parameters are shared, then you can schedule those as well and control it from the schedule as well.
heichan88
 Sorry I posted wrong
