how to offset with a instance-formula istance for a MASS form
heichan88
heichan88
I need to create a mass form by a loop of 3D lines (green line)which offset from 3D-snapping points (red dots)
the offset distance ("a") need to be a flex instance formula
Please advice how, thanks
Are you trying to create a parametric wedge-shaped form?
heichan88
hello @barthbradley
it is not wedge, it is a main corner beam which bottom edge ti be offset (“a”) from a flex distance from the edge of red joist  (a=width of red joist, which varies)
if offset by 3D point, the distance of host is U-V, not controllable, and if offset from a reference line betwee two 3D points, the mass will be conflicted unable to create a form, as I tried
Not enough information.  Offset based on which direction?  There can be millions of points orbiting the original point with the same distance.
Huh? I understood "hello barthbradley", but nothing else.  Maybe if you post your Revit file, I'll be able to figure out what you are trying to do.
heichan88
hello @barthbradley
Please find the rvt, the purpose is a corner beam which bottom =a offset (flex formula) from the red joist (3D snapping)
heichan88
OK, I am done with generic model adaptive, though 26 ap a bit complicated
