How to move room tag's base point
owen_bentley
Message 1 of 29
owen_bentley
I want the room tag base point to be at the centre of the text rather than at the bottom. This is because where I drag a tag to the bottom corner of a small room to fit it in, it moves outside the room boundary, making it invalid.
I've searched through forums where one solution suggested creating invisible lines at the top and bottom of the family. Unfortunately this didn't work.
Any help would be appreciated!
(see screenshots as attached)
Replies (28)
Message 2 of 29
Check Leader Line and drag the Tag to where you want it.
....are you wanting to move the origin? The origin in Visible when you turn on "Reference" Subcategory under Room Category in VGOs.
Message 3 of 29
Message 4 of 29
constantin.stroescu
you can use Dynamo for this. You have to load Rhytm Package for this:
Constantin Stroescu
Message 5 of 29
sorry, the correct spelling of the Package is : Rhythm
Constantin Stroescu
Message 6 of 29
owen_bentley
I'd rather not turn the leader line on as the text fits within the room and there would be a random line showing in the middle of the room (as attached screencast).
I'm don't know if it's the room origin that needs moving. Is it not possible to move the 'origin' of the room tag? There seems to be a specific point at the bottom of the tag which is triggering the error when it moves out the room zone.
Message 7 of 29
owen_bentley
screencast video
Message 8 of 29
You need to go to VGO's and turn on the Reference Subcategory under Rooms and then you can grab the origin and move it.
Message 9 of 29
RSomppi
Edit the family and move the objects within the family so that they are centered on the origin.
Message 10 of 29
owen_bentley
I've moved the points but I'm still getting the same issue.
Message 11 of 29
owen_bentley
Thank you, this has worked!
Is there no way to change the origin point of the family? The project has a fair amount of rooms so it would save having to move all the tags.
Message 12 of 29
Can you restate the issue?
Message 13 of 29
RSomppi
Did you try moving the reference plains that set the origin? I didn't think it would work but it might.
Message 14 of 29
owen_bentley
When I drag my room tag to the corner of one of my small rooms, revit doesn't recognise that it still sits within that room's boundary. This is something to do with the fact that the room tag's 'origin' point seems to be sitting below the lines of text.
I have solved this issue simply by moving the text within the family downwards as per @RSomppi suggestion.
However, I'm looking to see if there is a way to move the actual origin point to save moving all of the room tags which have already been placed
Message 15 of 29
Okay, unless the labels in the tag family were way the heck away from the x,y Origin Ref. Plane, I have no idea how that would "work".  Were they? If not, then I wouldn't be moving them.
Tell you what - post your file and let us inspect it.  Do you know how to do that?
Message 16 of 29
owen_bentley
There aren't reference lines existing within the family.
I tried creating some, but to no avail. It still seems to be dictated by this invisible origin point.
Message 17 of 29
Turn them on under VGO's Annotation Category.
Message 18 of 29
RSomppi
Yes, there are. You have them turned off in the visibility settings V/G Overrides.
Message 19 of 29
owen_bentley
Thanks, please see attached for the annotation family.
I've played around with the reference plane and there doesn't seem to be a correlation with it's room bounding origin point.
Message 20 of 29
This Tag Family is fine.  You don't need to mess with it.
Post the RVT (Project) that you're having issues with.
