How to move automatic cuts in floor or ceiling at the same time as an object?
felipe_gonzalez-gil
felipe_gonzalez-gil
Hi everyone,
I´m trying to reference the movemento from a cut on the floor with the movement from an object. Does anyone knows how to do it, to avoid always to modify the movement from the cut in the floor. Thanks
BDMackey
If this is based on a single family element then that void could become part of the component. If you are talking about a shaft then look at the Shaft Opening command utilizing the pick walls feature.  If this is just a bunch of elements then there isn't a great option for that.
felipe_gonzalez-gil
Well actually what I´m trying to do is find a way to do a trim with two floors, like the same cut option without the void extrusions. At the moment unsuccesful. Thanks anyway for the explain.
BDMackey
Not sure the circumstance here but you can model a single floor, create parts from that floor, Then you can divide the part which would involve a single division for both sides, then you can change the material on one of those parts.  I use this all the time for finish floors and it works well.  Just need the team to understand the views need to display parts in properties and that they aren't part of the floor category now the part category.
What do you mean by "a trim with two floors"?  Your screenshot shows a hole in the floor.  Do you want that hole move along with the kitchen?
