NEVER, NEVER use Move command to move building model vertically!
Of course, this doesn't apply on moving furniture and similar elements that will not break you construction.
Everything in Revit is attached to something (Level or Reference plan) so you need to have that in mind.
If you are moving your model vertically you will move your project base point.
So, turn on the project base point. This is "the zero of the model" and it represents the building.
On the other hand, there is a Survey point which represents the "World" (yes, planet Earth 😉 )
So, I imagine that you need to "move" everything up or down for some value. Your Zero level should be for example +1,1m, not 0,0m.
What you will do is next:
- unclip your Project base point and
- enter the new eleveation value.
Level 0,00 is where the project base point is.
- Clip the project base point.
Be carefull, if you enter new elevation value into your Project base point while it is still clipped to the model, then the whole model will move. Moving clipped Project base point moves the model, while moving clipped Survey point moves the world below the model.
Hope it helps.
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
