How to modify exterior elevation tag
jayartadle
Message 1 of 8
jayartadle
I want to modify exterior elevation tag because currently I'm using on the left side but I want it  to be the same in the right side which always horizontal position of text. Sorry for this question I'm just beginner in Revit.
Replies (7)
Message 2 of 8
RDAOU
@jayartadle
For Revit 2021 and 2022...you can edit the Section Head annotation family and uncheck the "Rotate text with Component"
  • Select the section in a plan view
  • Edit it's type and check which Section Head family is in use
  • Exit dialog and In the project Browser >> Under Families/Annotation Symbols >> Locate the Section head family
  • Edit the family >> Uncheck "Rotate text with Component" >> Reload into the project
Message 3 of 8
jayartadle
Can you make sample for Building Elevation Exterior Tag.
Message 4 of 8
jayartadle
Please see attached family file for Elevation Exterior Tag.
Message 5 of 8
RDAOU
@jayartadle
You have placed the labels in the Pointer family...for the "Rotate Text with Component" to function as per message 2 above, the labels and the body must be in the Elevation Head family
Message 6 of 8
jayartadle
Sorry the other family file was for Interior tag.
Message 7 of 8
RDAOU
@jayartadle
Same principle ... The Labels need to be with the body in the main family + in this family you need to add 3 more pointers
Here I do not have 2021, the attached are the 2022 fixed version + see GIF below for how to:
  • Edit Body
  • Select Pointer >> Edit Family
  • Select Label >> Cut to clipboard
  • Reload Pointer to Body and Overwrite Parameters
  • Go to Modify Tab >> Paste from Clipboard (Aligned to Current View)
  • Make sure "Rotate text with Component" is unchecked
  • Save and Reload body to Project
Message 8 of 8
dbartlettMWWEU
Just wanted to thank you for the robust and thorough response, not only did you show me how to do exactly what I was trying to do, you made a freaking gif of the process for illustration. Class act
