@Anonymous wrote:
I will try it, I don't understand how (like a curtain wall with grid) but let me see. so I draw a roof and then I'm going to put it on top of the floor?
Yes.
- Draw a roof, pick the Sloped glazing type down the bottom of the Roof type list. Then modify the type properties as I've shown.
- Keep the default panel of the roof type as None (I showed it as CPT1 but None is more flexible to change panel types).
- Go to the Project Browser > Families > Curtain Panels > System panel: right click on Solid and duplicate to create a new type, change its thickness and material to a carpet type 1.
- Repeat to create the panel carpet type 2.
- Go back to your model, select a bunch of panels and change their type to carpet type 1 or 2.
- When the room changes, just edit the foorprint, you can even lock the footprint to the walls if you want. You can copy a roof to a different room and change the footprint to match.
